In seatable 2.0 it was possible to use a column which value was calculated with a formula as the title of a calendar event. In 2.1 it does not work anymore (the title is not displayed if it is linked to a “formula type” column. Is this regression a planned limitation or a bug ?
By the way, I’ve got another small question regarding the calendar plugin. Is a copy paste feature planned ? This is really a must have feature for editing calendar events.
What would be great would be to have a contextual menu when you right click on an event. This would allow to either : duplicate the event in place (as if you were duplicating a row in the table that contains the events) or copy it in the clipboard. Then if you right click on the calendar anywhere, another contextual menu would allow to paste the event (possibly not in the same week as the original (copied) event.
In the calendar, you can drag and drop an “event” which is actually a row from one date to another one. It would be of course even better if you can copy and paste them.
Do you know the click&pull feature in the calendar menu?
In other words: You can already create new events in the calendar view. I would say this is even more elegant than the context menu option you propose.
This said: I realize that you cannot copy/duplicate events this way.
Yes I’m aware of click+pull and of the possibility of moving events once created. They are very convenient, the only missing feature is duplication / copy paste.
By the way there is another “bug” or missing feature in the calendar plugin (unless I missed something). Only the month view can be printed, the other views are not available / proposed when clicking the print icon. It’s a pity because (for me) the most frequently used views are the week view and the agenda.
The printing menu is in the same level as the view of the calendar, and we currently only have a month view. So this is rather a feature request than a bug. I will list this!
Why do you say there is only a month view for the calendar ? There is a year, month, week, day and agenda view in the plugin. Or maybe we are not talking about the same “view” ?
Thank you for this new version. Unfortunately the regression is not fixed. In fact it is partially fixed… It now works for calculated fields if the output is a number, but if the output is a text string it still does not show anything :-(.
Best regards,
Well this is really strange because on my side it works for some fields but not others.
In particular I have a summary (résumé) field (see below) and the calendar view does not want to show it in the title of the events (but it works with the week (semaine) field)…
I just tested again using your column name “résumé”. I was thinking “maby there is an issue with the non-asci characters”. But there isn’t. I had no problems.
If you want us to investigate further, could you send an invite link for this base to support@seatable.io?
