AkDk7
21
So basically what you have to do is…
- Get the changed row
- Get all rows of table People
- Iterate over 2.
- Compare the rowId of 1. with the content of the array of the column “Training 1”
- If that matches add (append a new item to the list) or update (overwrite the list with one or more items) the link for the column Autonomous
That should do the trick.
Ben
22
Yes, that was mosty my plan.
I need to add a loop to search for the correct row to update.
For now, its holidays
Thanks for confirming my plan.
I’ll work on that after a whole week far away from internet
system
Closed
23
