I’ve got a free subscription
the problem is I can login but if I want to open a Table - its just doesn’t come!
It loads forever.
Anyone has an idea what to do?
Welcome to the SeaTable Forum!
Our cloud service is running well at the moment. So it should be something in your base that’s preventing it from opening. Sometimes an abnormal change to a base could lead to this problem.
Press Shift+F5 and try again. If problem is still there:
My questions for you:
- Is it happening with all your bases or just one? If only one -
- How many rows are there in that base?
- If you go to “Activities”, you can see the last changes made to your base. What’s the last change you’ve made to that problematic base?
Is your problem solved?
