It is pretty great how it is possible to rearrange columns in SeaTable without much effort.
But now I ran into an issue with a pretty large table in which a date column is the first, or “primary”, column. It would be much preferrable for purposes of references to use a text column for the primary column, but it is impossible to move this column into the primary position via drag/drop, nor is it possible to create a new column to the left of the primary column.
I am missing something obvious here?
For a little background, the table was created via an Excel file import that just happened to have a date column on the leftmost side. It wouldn’t be possible to change the source Excel file and re-import because considerable work has already been done on the data in SeaTable.
