I am also facing this issue. My setup is Seatable version 2.7 installed on a self hosted server. As there are other services that are activated on the same server I am using Caddy as a reverse proxy. The host port of 4431 is redirected to 443 port of the seatable server container. I can access seatable and create bases / tables etc without issues. I can also create common datasets - however, they will not get imported.
I am not using the nginx reverse proxy in the seatable container to ask for SSL certificate as Caddy provides the SSL certificate automatically. I have configured the nginx.conf file as below :
log_format seatableformat '[$time_iso8601] $http_x_forwarded_for $remote_addr "$request" $status $body_bytes_sent "$http_referer" "$http_user_agent" $upstream_response_time';
upstream dtable_servers {
server 127.0.0.1:5000;
keepalive 15;
server {
if ($host = seatable.XXX) {
return 301 https://$host$request_uri;
listen 80;
server_name seatable.XXX;
return 404;
server {
listen 443;
# for letsencrypt
location /.well-known/acme-challenge/ {
alias /var/www/challenges/;
try_files $uri =404;
proxy_set_header X-Forwarded-For $remote_addr;
location / {
add_header Access-Control-Allow-Origin *;
add_header Access-Control-Allow-Methods GET,POST,PUT,DELETE,OPTIONS;
add_header Access-Control-Allow-Headers "deviceType,token, authorization, content-type";
if ($request_method = 'OPTIONS') {
return 204;
proxy_pass http://127.0.0.1:8000;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Host $server_name;
proxy_read_timeout 1200s;
# used for view/edit office file via Office Online Server
client_max_body_size 0;
access_log /opt/nginx-logs/dtable-web.access.log seatableformat;
error_log /opt/nginx-logs/dtable-web.error.log;
location /seafhttp {
rewrite ^/seafhttp(.*)$ $1 break;
proxy_pass http://127.0.0.1:8082;
proxy_request_buffering off;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
access_log /opt/nginx-logs/seafhttp.access.log seatableformat;
error_log /opt/nginx-logs/seafhttp.error.log;
location /media {
root /opt/seatable/seatable-server-latest/dtable-web;
location /socket.io {
proxy_pass http://dtable_servers;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection 'upgrade';
proxy_redirect off;
proxy_buffers 8 32k;
proxy_buffer_size 64k;
proxy_set_header Host $http_host;
proxy_set_header X-NginX-Proxy true;
access_log /opt/nginx-logs/socket-io.access.log seatableformat;
error_log /opt/nginx-logs/socket-io.error.log;
location /dtable-server {
return 204;
rewrite ^/dtable-server/(.*)$ /$1 break;
proxy_redirect off;
proxy_set_header X-Forwarded-Proto $scheme;
# used for import excel
client_max_body_size 100m;
access_log /opt/nginx-logs/dtable-server.access.log seatableformat;
error_log /opt/nginx-logs/dtable-server.error.log;
location /dtable-db/ {
return 204;
proxy_pass http://127.0.0.1:7777/;
proxy_redirect off;
access_log /opt/nginx-logs/dtable-db.access.log seatableformat;
error_log /opt/nginx-logs/dtable-db.error.log;
Note that XXX refers to my domain name.
My dtable-websettings.conf is as follows:
DATABASES = {
'default': {
'ENGINE': 'django.db.backends.mysql',
'HOST': 'db',
'PORT': '3306',
'USER': 'root',
'PASSWORD': 'PASSWORD',
'NAME': 'dtable_db',
'OPTIONS': {
'charset': 'utf8mb4',
CACHES = {
'default': {
'BACKEND': 'django_pylibmc.memcached.PyLibMCCache',
'LOCATION': 'memcached',
'locmem': {
'BACKEND': 'django.core.cache.backends.locmem.LocMemCache',
COMPRESS_CACHE_BACKEND = 'locmem'
SECRET_KEY = 'YYY'
# for dtable-server
DTABLE_PRIVATE_KEY = 'YYY'
DTABLE_SERVER_URL = 'https://seatable.XXX/dtable-server/'
DTABLE_SOCKET_URL = 'https://seatable.XXX/'
# for dtable-web
DTABLE_WEB_SERVICE_URL = 'https://seatable.XXX/'
# for dtable-db
DTABLE_DB_URL = 'https://seatable.XXX/dtable-db/'
# for seaf-server
FILE_SERVER_ROOT = 'https://seatable.XXX/seafhttp/'
PLUGINS_REPO_ID='a1e654f5-ebe1-49f7-86ca-4e5181d2b21c'
I have also ensured that the same URL is provided in the ccnet.conf file
I am getting the following error in the dtable-events.log
2022-03-14 01:36:21,306 [ERROR] request src_dtable: 74848d8e-c4e2-4b68-8406-bcd5f62befbd params: {'table_name': 'Table1', 'view_name': 'Default View', 'use_dtable_db': True, 'start': 0, 'limit': 10000} view-rows error: HTTPSConnectionPool(host='seatable.XXX', port=443): Max retries exceeded with url: /dtable-server/api/v1/internal/dtables/74848d8e-c4e2-4b68-8406-bcd5f62befbd/view-rows/?from=dtable_events&table_name=Table1&view_name=Default+View&use_dtable_db=True&start=0&limit=10000 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f4552f83350>: Failed to establish a new connection: [Errno 110] Connection timed out'))
2022-03-14 01:36:21,306 [INFO] Run task success: 1647201850555 <function import_common_dataset at 0x7f4552fd73b0> cost 130s
Would be happy to have any assistance to solve this issue.
