I have a table. Different Column-Types. Now I want to move DONE & ARCHIVED Items to an ARCHIVE-Version of this table, to get items out of the way. No way possible! All info in columns containing relations to other tables is lost. Also there is no way to export and import the items. I’m lost. Thx for help, Hagen
PS: Using a button to copy the item to another table … also doesn’t work
Thank you so far … so now I searched for quite some time for this “archiving”-feature. I guess I tried every menu and button at least twice. WHERE IS IT?
Hey Hagen,
archiving feature is still in beta and therefore not activated for cloud.seatable.io.
There are different possibilities to copy / backup / save data. It depends of the use case you have. Here are some of the options you have
