Copy View settings
Hello, is it possible to copy the settings from one view to another? I have several views with filtered data from the same table, but when I make a change in one view, I have to manually apply the same change to the others. I would also like to copy or edit the width of a column.
Thanks!
You can duplicate views. When duplicating a view, the new view inherits all filter/sort/group settings from the duplicate view.
Once a view has been created, it stands on its own.
The rationale behind views is that they provide different viewpoints at the data. Different viewpoints implies different view settings (i.e. filters).
Yes, but sometimes different views are based on the same principle, with only a couple of different filters, groups, or sorts. If I make some edits—like showing or hiding several columns—in the “main view”, I have to apply those edits manually to all the other views, and in my case, there are several.
For two of our power users, I had the same requirement: They have literally >50 views which are identical, only differing in one aspect (for different user groups / departments, the filter parameter contains a different string, which filters the records that only one department should see).
Duplicating didn’t cut it: When they needed to change something (e.g. add a column) later, they had to add it to each of the 50+ views manually. Which was not only tedious, but very error-prone.
I ended up with a workflow using n8n:
  • n8n reads the filter settings from one “master view” that I defined, and writes them into columns within a special seatable table.
    • Filter, Sort, Grouping etc. in separate columns, and as Json strings. The latter is not user friendly, but those are power users.
  • The base Designers can then copy and change that line in the Seatable table.
    • A webhook in n8n reacts to those changes.
    • If a view corresponding to the line (by name) does not exist, it is created via th API.
    • The view (either existing or newly created) then gets the master view’s settings.
  • In real life, it’s even more complicated: The master view’s settings (Json strings) can be manipulated by a formula, e.g. a placeholder can be replaced with individual values for each line.
Maybe that gives you an idea.
