Duration column in forms (format h:mm)
Hello everyone,
I just discovered a bug while trying to use a column of type Duration when adding rows from Forms : the value entered in the form is multiplied by 60 in the table. For example, an input of 3:00 (format h:mm) will appear in the table as a record with duration of 180:00.
With format h:mm:ss everything works fine, but with format h:mm the number of hours seems to be multiplied by 60.
Thanks for reporting.
This is a known bug and will be fixed in the soon-to-be-release version 2.2.
Hi Benjamin, the new SeaTable 2.2 should have solved your issue. Could you check and mark this issue as solved if it is?
