I installed seatable in enterprise version on a single node.
The installation is on AWS, with a load balancer that has a self-signed ssl certificate.
This is what it looks like:
User → LB with SSL → Foward to :80 → SeaTable Enterprise Host (no public ip)
If i keep all configs url for seatable on HTTP I’ve an network error when I try to access to an table.
If i change all configs url on HTTPS all works fine but not the Import/Export function whatever the format.
On dtable_web.log:
django.request:230 log_response Not Found: /api/v2.1/workspace/1/dtable/Untitled base/export-table-to-excel/
Same for plugins:
2022-10-22 14:04:41,125 [ERROR] django.request:230 log_response Internal Server Error: /api/v2.1/admin/dtable-system-plugins/
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/exception.py", line 47, in inner
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/base.py", line 181, in _get_response
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/views/decorators/csrf.py", line 54, in wrapped_view
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/views/generic/base.py", line 70, in view
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 509, in dispatch
response = self.handle_exception(exc)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 469, in handle_exception
self.raise_uncaught_exception(exc)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 480, in raise_uncaught_exception
raise exc
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 506, in dispatch
response = handler(request, *args, **kwargs)
File "/opt/seatable/seatable-server-latest/dtable-web/seahub/api2/endpoints/admin/sys_plugins.py", line 186, in post
plugin_path_id = seafile_api.get_dir_id_by_path(PLUGINS_REPO_ID, plugin_path)
File "/opt/seatable/seatable-server-latest/seafile/lib/python3/site-packages/seaserv/api.py", line 256, in get_dir_id_by_path
return seafserv_threaded_rpc.get_dir_id_by_path(repo_id, path)
File "/opt/seatable/seatable-server-latest/seafile/lib/python3/site-packages/pysearpc/client.py", line 127, in newfunc
return fret(ret_str)
File "/opt/seatable/seatable-server-latest/seafile/lib/python3/site-packages/pysearpc/client.py", line 25, in _fret_string
raise SearpcError(dicts['err_msg'])
pysearpc.common.SearpcError: Get repo error
Is this something you’ve encountered before ?
Thanks !
