Feld in Formular verknüpfen
Hi, ich habe ein Tabellenblatt mit Projekttiteln und möchte in einem Formular diese Projekttitel mit “Option auswählen” zur Auswahl geben. Das Formular besteht bereits. Wie kann ich das Feld “Option auswählen” mit den Projekttiteln verlinken? Kann mir jemand helfen?
Hallo und willkommen im SeaTable-Forum !
Entschuldigung, ich werde auf Englisch antworten: Ich habe Deutsch gelernt, als ich ein Student war, aber ich habe fast alles vergessen :cry:
I presume the form doesn’t feed the same table than the one with the projects right ? If I’m right, and as far as I understand your problem, you have two solutions:
  • Creating a new single-select column and a blank row, then copying-pasting the content of your title’s column in the single select cell of the blank row. This will add as much rows as you have projects. You can delete these rows, the purpose was only to create the options of the single-select column (if the form feeds the same table than your projects, just copy-paste the content of your title’s column in your single-select column). The disadvantage of this solution is that each time you add a new project, you’ll have not to forget to add the corresponding option in the single-select options
  • Using a link to other record (Verknüpfung zu anderen Einträgen) column instead of a single-select column. Doing so, adding a new project will automatically show the corresponding option in the form. If you have two different tables as I presumed, it’s pretty straightforward. If you have one single table, you’ll have to create a separate view to filter only the projects you want to show in the dropdown selection menu and configure this link to other record column to be able to pick records only from a specific view
    Hope this helps…
I love spending time gathering information and explaining solutions to help you solve your problems. I spend… quite a bit of time on it :sweat_smile: .If you feel grateful for the help I’ve given you, please don’t hesitate to support me. I am also available for paid services (scripts, database architecture, custom development, etc.).
Vielen Dank! Meine Tabelle ist fast fertig :grinning: Kann ich in Felder mit “Einfachauswahl” in einen längeren Text einen Zeilenumbruch einfügen? Hier steht nicht “ja” oder “nein” zur Auswahl sondern längere Sätze.
Hallo !
Leider glaube ich, dass es nicht möglich ist…
ok thank you :slight_smile:
