We use SeaTable Enterprise and ask ourselves how to set fine-grained access rights within a group or a section (in administration panel, in German: “Bereiche”).
Example:
Group “Controlling” contains Bases A, B and C.
Group “Controlling” contains Users X, Y and Z
How can I e.g. authorize user Z only to base A, but not to B and C?
And what is the difference between a group and a range? Unfortunately I didn’t find anything in the documentation about the section.
This is currently not supported. (I am also not sure if such fine-grained group permissions would make sense. It would kind of put the idea of groups on its head.)
short answer:
the logic of SeaTable is simple: every user that is assigned to a group has read and write access to all bases of that group. Create more groups with different members to create a more fine-grained permission.
Long answer:
let me try to explain the different possibilities of SeaTable. I will also try to differenciate between SeaTable Cloud and a self hosted server:
SeaTable Cloud https://cloud.seatable.io is a shared system. Right now you have teams, groups and users. A team represents a company, a team or just a bunch or people that wanna work together. Teams are separated from each other and you can’t see other teams in cloud.seatable.io The subscription is connected to a team, thus you can not say: half of the users of a team have SeaTable Free and the other half have SeaTable Plus. You have one kind of subscription for all team members.
Inside a team you have groups. Groups contain bases and users are assigend to groups. The logik is simple. Each user that is assigned to a group has write access to the bases of this group.
You find more information about groups in our manual: Groups - SeaTable.
Last hint: I said that teams are separated from each other. SeaTable still allows to share a base to another team (read/write or read-only). But the possibilities to work together with separate teams are quite limited.
SeaTable on-premises
usually on your server you don’t separate teams from each other. On the other hand you have so called “Bereiche” to add users together.
I hope my explanation helps. We will try to enhance our manual as soon as possible.
Best regards
