Hello , i think there is something wrong with group by.
if i am not wrong, when i select group by 1 column only, it should group all of 3108 together ( regardless of other column )
However, as shown in my screenshot, the group is separated by “DOC type” column as well.
This is weird. Could you export the table in a DTABLE file and send to support@seatable.io? (Pleae remove private data.)
Got it. We’ll have a look.
This is not an issue but a designed behaviour. When group over a link column, rows are grouped by linked row’s id.
If you want to group by linked row’s first column value, you can first create a lookup
link formula, then group by this formula column.
