Help formula to get together text separate by _
Hello
i need to create a formula and get 4 columns together, but what the beginning I want to insert “_” but i don’t know how to do that.
i inserted the formula to get the fields from columns.
“{N_OPM}& {Instalação_sap}& {SAP_ID.N_Painel}& {nomepdf}”
And i the end, I need something like this “12345_text text_e12345”
Sorry for my English
thanks for all the help
Hi @andreven , and welcome on the forum !
You were almost there ! You just need to add your character as you shown in your message:
{N_OPM} & "_" & {Instalação_sap} & "_" & {SAP_ID.N_Painel} & "_" & {nomepdf}
thanks for the help just work fine.
i try to add like i write but i only put one &.
