i’m quite new to SeaTable. I have installed the Developer Edition in my homelab and started creating my first bases.
One of the things i wanted to try out with SeaTable was a recipe database.The idea is to gather “the good recipes” from within my family (like my mother or parents in law). I’d like to use the webforms, which i think would be the ideal way to do it.
I have started creating a base and some tables. My first tables are
- Recipes with the columns Name, Ingredients (Is a link to another table) and Description
- Ingredients with the columns Name, Amount and Unit
With these two i stumbled upon the fact, that you cannot create child rows within a web form. That means that i have to create the ingredients first, and then assign them to the recipe (is that correct)?
The reason, why i want the ingredients to be in a separate table is to have the ability later on, to create shopping lists out of it.
Is there in general a good template for my idea? What do you think about my approach?
Thanks and BR,
Michael
