I am trying to update a table via Integromat/Make and am absolutely stuck. Can someone help?
What I am trying to do:
A web form submits details of a user.
- A new record is created in Table A - OK
- Next, I want to search Table B to see if the user already exists. If the user already exists in Table B, one column is updated in Table B. If not, a new row/record is created in Table B using the data from Table A.
Part 2 is where I am completely stuck. I have tried “list rows” and “get a row” and also using filters (if exists/not exists, if equal to not equal to) but I am unable to update existing rows (usually bad parameters message).
What is the correct sequence of modules to achieve this? Where can I enter the search term in “get a row”?
