Hello folks,
New with seatable I try to understand how to use the date in filter.
eg: I want to filter data between 2 dates.
When I use the filter “after” “exact date”, which syntax do I have to use?
I tried dd/mm/yyyy , with no success …
Hello, welcome to the SeaTable Forum!
For filter conditions, the European format is not supported. Try using ISO (YYYY-MM-DD) or US (M/D/YYYY) format should be the solution!
