I want to import an Excel spreadsheet with a logical field. This field contains “true” or “false”. Is it possible that when importing Seatable, a column “checkbox” is made of it. currently it becomes a text column for me.
Simply convert it to a checkbox after the import.
Apologies, my previous answer was a little brief.
SeaTable converts every cell value in a text column in a checked checkbox. Every empty box is converted in a unchecked checkbox.
Hence: After importing the Excel table, use the search & replace to purge all “False” from the column and convert then to column type checkbox.
Yes, this works perfekt.
Thank you very much
