I´m new to SeaTable and have a little Problem. Maybe someone can help me out.
I try to export a DTable Content via a api, so i can parse the DTable content in an application for automatic computations. I found this api documentation here.
As far as I see the workflow I have to use the “Export DTable” interface (api/v2.1/workspace/<workspace_id>/dtable//export-dtable/) to get a task_id and a dtable_uuid, which I can use than for the " Get Export Content" interface. The first step works perfectly fine, the second one returns me a 404 Not Found response.
I checked the status of the task_id and discoverd that the task is finished immidiatly after I created it over the “Export DTable” interface. Is this correct? I assume that the task should be not finished and can be used to export the DTable Content, before I can Cancel the Task by myself over the api.
I asume that the 404 happen because the task_id is alread finished when i ask for the DTable content with the finished task id, but the response does not tell me excactly the origin of the issue.
My Question: Did I misunderstood the way how to export the DTable content via api or is this indeed a problem with the task_id?
thakns for your response. I try this at the moment at a NOT self hosted environment. Over the WEB UI i get my export without any problems. If it works there, maybe I understood the API wrong?
Also good point with the rows, I will try if this fits to my usecase to get all values from a specific column.
Dear Steffen,
Do you really want to download the content of a base as a total or do you want to get access to the content of a table?
There are two points I want to make:
if you want to get an easy way to copy the content of seatable to another application, then zapier.com might be a good solution for you: https://zapier.com/apps/seatable/integrations. With zapier it is super easy to check for new values in a base and then execute another action like a webhook or an action in another application.
if you want to use the api to get the content of a base then the “export” api call is not the right one. I can provide you with example code how to get access of the data of a base.
Best regards
