I am running a Docker installation and having issues with the export feature. The installation has been upgraded today to the latest version (3.2), but the issue was already present before and it’s still here.
First of all, I have changed the file size limit to a very large number, to avoid issues on this side.
While checking the log, it seems that the base cannot be exported due to a JSON error:
2022-10-27 11:54:08,280 [INFO] Run task: 1666864448279 <function get_dtable_export_content at 0x7f5b066c7200>
2022-10-27 11:54:08,280 [INFO] Start prepare /tmp/dtable-io/64629667-ad03-4dee-aad6-7e20c191c70f/zip_file.zip for export DTable.
2022-10-27 11:54:08,281 [INFO] Clear tmp dirs and files before prepare.
2022-10-27 11:54:08,281 [INFO] Create content.json file.
2022-10-27 11:54:08,437 [INFO] Create asset dir.
2022-10-27 11:54:09,441 [ERROR] create asset folder failed. ERROR: the JSON object must be str, bytes or bytearray, not NoneType
2022-10-27 11:54:09,441 [ERROR] Failed to handle task 1666864448279, error: create asset folder failed. ERROR: the JSON object must be str, bytes or bytearray, not NoneType
As stated in the thread, this is a Docker installation that has been set up using the official installation guide. I am not sure if we can reach support via email and what is the “ID of the affected base”.
Thank you.
