Hello, i use datedif formula to calculate difference between today and date of birth. It works in table view.
however, in kanban view, whenever i change the switch to on, it crash… Is it only me or there is a bug in the plugin.
Thanks for the report. We’ll have a look and come back to you soon.
Hi, I couldn’t reproduce the problem.
If it’s OK, please forward an external link, or an export of your base to support@seatable.io. Also include the current version of your installation (version number and edition).
@Karlheinz send you a message, you can try out… the are dummy data that i key in yesterday for testing…
Got it. I’ll give it a look and come back to you soon. Thanks.
Did you find a solution to your problem? Are you still encountering the problem?
@htoolin I assume you did not answer because the problem has been solved/disappeard. If not, please comment.
Hello, problem is solved after i update the plugin…
Great, glad to hear that!
