Lookup. Nothing selectable
Hello everyone,
I have a problem with the link to another table. I would like to display the contact persons from the Contacts table. Unfortunately, there is still something to select in the “Lookup column…” under the item: “Link column in this table”. What am I doing wrong?
Thanks for your help
Hey,
It looks as if you have not yet created a link between the two tables.
First you have to add the column Link to other records, then you can use columns of the type link formula.
Thank you. The problem was that I could not convert the existing column “Contact person” into the type “Link to other entries”. Now it works.
