Can foreign key be the primary key? It’s useful when design inherit table or multi-layer quote.
I found this in lots of similar products like vika or hipa cloud, they allow you set formula or foreign column as primary key, so I wonder if seatable have any plan on this feature?
There is no need to use formula as the first column.
If you want to display a different column other than the first column in cells of link column, you can choose another column in the linked table to display.
When you choose rows to link, you can search rows by multiple fields, not only the first column.
Thanks for the reply, but you didn’t get my point.
Yes I can choose another column, but can’t choose the linked column in the linked table.
Yes I can search rows by multiple fields, but can’t search from the linked column in the linked table.
Even if I convert the linked column to formula column, still, I can’t search it.
