my seatable DE was running smoothly.
I made the upgrade following the usual Upgrade Manual - SeaTable Admin Manual
All docker appear working in portainer, but I reach a :
Page unavailable
Sorry, but the requested page is unavailable due to a server hiccup.
Our engineers have been notified, so check back later.
Starting seatable-redis ... done
Starting seatable-memcached ... done
Starting seatable-mysql ... done
Starting seatable ... done
Attaching to seatable-redis, seatable-mysql, seatable-memcached, seatable
seatable-redis | 1:C 21 Mar 2023 14:28:39.705 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
seatable-redis | 1:C 21 Mar 2023 14:28:39.705 # Redis version=5.0.7, bits=64, commit=00000000, modified=0, pid=1, just started
seatable-redis | 1:C 21 Mar 2023 14:28:39.705 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf
seatable-redis | 1:M 21 Mar 2023 14:28:39.706 * Running mode=standalone, port=6379.
seatable-redis | 1:M 21 Mar 2023 14:28:39.706 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
seatable-redis | 1:M 21 Mar 2023 14:28:39.706 # Server initialized
seatable-redis | 1:M 21 Mar 2023 14:28:39.706 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
seatable-redis | 1:M 21 Mar 2023 14:28:39.706 # WARNING you have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command 'echo never > /sys/kernel/mm/transparent_hugepage/enabled' as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled.
seatable-redis | 1:M 21 Mar 2023 14:28:39.706 * DB loaded from disk: 0.000 seconds
seatable-redis | 1:M 21 Mar 2023 14:28:39.706 * Ready to accept connections
seatable-mysql | 2023-03-21 14:28:39+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.13+maria~focal started.
seatable-mysql | 2023-03-21 14:28:40+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
seatable-mysql | 2023-03-21 14:28:40+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.13+maria~focal started.
seatable-mysql | 2023-03-21 14:28:40 0 [Note] mysqld (mysqld 10.5.13-MariaDB-1:10.5.13+maria~focal) starting as process 1 ...
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Uses event mutexes
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Number of pools: 1
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
seatable-mysql | 2023-03-21 14:28:40 0 [Note] mysqld: O_TMPFILE is not supported on /tmp (disabling future attempts)
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Using Linux native AIO
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Completed initialization of buffer pool
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: 128 rollback segments are active.
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Creating shared tablespace for temporary tables
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: 10.5.13 started; log sequence number 333504173; transaction id 507852
seatable-mysql | 2023-03-21 14:28:40 0 [Note] Plugin 'FEEDBACK' is disabled.
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
seatable-mysql | 2023-03-21 14:28:40 0 [Note] Server socket created on IP: '::'.
seatable-mysql | 2023-03-21 14:28:40 0 [Warning] 'proxies_priv' entry '@% root@32c6523cdf56' ignored in --skip-name-resolve mode.
seatable-mysql | 2023-03-21 14:28:40 0 [Note] Reading of all Master_info entries succeeded
seatable-mysql | 2023-03-21 14:28:40 0 [Note] Added new Master_info '' to hash table
seatable-mysql | 2023-03-21 14:28:40 0 [Note] mysqld: ready for connections.
seatable-mysql | Version: '10.5.13-MariaDB-1:10.5.13+maria~focal' socket: '/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution
seatable-mysql | 2023-03-21 14:28:40 0 [Note] InnoDB: Buffer pool(s) load completed at 230321 14:28:40
seatable | *** Running /etc/my_init.d/01_init.sh...
seatable | *** Booting runit daemon...
seatable | *** Runit started as PID 15
seatable | *** Running /templates/enterpoint.sh...
seatable | 2023-03-21 14:28:40 Conf exists
seatable | 2023-03-21 14:28:40 Nginx ready
seatable | 2023-03-21 14:28:40 This is an idle script (infinite loop) to keep container running.
I’m stuck …
help
