I’m using the DE of seatable and i have tried the n8n automation.
I’m still not working on the trigger, just the API.
it’s working well but I’m facing a wall.
I have to get all lines of a specific field then write them to another table.
it’s running smoothly up to line 1000.
then it crashes with an error 40 - too many operation.
“message”: “Request failed with status code 400”,
“name”: “Error”,
“stack”: “Error: Request failed with status code 400 at createError (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/core/createError.js:16:15) at settle (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/core/settle.js:17:12) at IncomingMessage.handleStreamEnd (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/adapters/http.js:269:11) at IncomingMessage.emit (events.js:327:22) at endReadableNT (internal/streams/readable.js:1327:12) at processTicksAndRejections (internal/process/task_queues.js:80:21)”
