I’m trying to copy multiple values in a seatable base.
I’ve got an issue with copy/pasting numbers from my excel to columns separated with a comma.
Whatever the separator chosen (comma or point), it doesn’t work when coming from a number formatted cell in excel.
All number pasted are considered as having no separator.
73,74 becomes 7374
If i force the separator as a point (replacing in excel the comma with a point via Search-and-replace), it works.
It gets even worse, when you have a “dot . thousand” seperator. And even after fixing it, with replacing the dots first and then replacing the , with . in a text editor, there are still mistakes, which I only found out about after comparing SUMs of COLUMNs. So … fixing this bug would be of great help!
We are sorry that the problem hasn’t been fixed yet.
There is a workaround though: When formatting the cells as “text” and using a dot as a decimal separator (see below), you can transfer data from Excel to SeaTable via copy-paste.
