Hi, I have started using the automation rules and can’t seem to find a way to create an automation rule to automate the data processing operation in the screenshot. Can you help?
We’ll add an automation to execute a data processing operation in SeaTable. When? Probably not in the coming release SeaTable 3.2, but with a little luck in SeaTable 3.3.
The procedure would be as follows:
- You create a data processing operation
- You create an automation which triggers the specified data processing operation
- You have SeaTable do your work for you
That seems like a great idea. Thanks!
