Hello.
i need to copy a line multiple times with the Button. There is a action already with the button but only for single copy. In my case i get 50 new items with the same basic parameter in my inventory.
It would be nice if you could press the button and then enter a number of copys. Is it possible to script it, unfortunately I don’t have the knowledge.
Nicolas
What does the title have to do with your post?
Am I also not sure what your post is. Is it a feature request? Or a request for support for someone else to write the script for you?
If it is a feature request, use https://ideas.seatable.io. If it is a support request, be more specific.
In summary, your post is a example for what you should not do in forum post.
