Hi
Is there a way to truncate a table? To delete all rows without having to delete it row by row?
Thank you
You can use query API with DELETE from xxx
Hi Daniel, thank you for the tip
It works, records are deleted, but it gives error after deletion
File "index.py", line 105, in <module>
test1 = base.query("DELETE from Edgelist")
File "/usr/local/lib/python3.7/site-packages/seatable_api/main.py", line 795, in query
data = parse_response(response)
File "/usr/local/lib/python3.7/site-packages/seatable_api/main.py", line 31, in parse_response
raise ConnectionError(response.status_code, response.text)
ConnectionError: [Errno 502] <html>
<head><title>502 Bad Gateway</title></head>
<body>
<center><h1>502 Bad Gateway</h1></center>
<hr><center>nginx/1.20.2</center>
</body>
</html>
This is caused by timeout of Nginx. You can ignore the error.
