The script feature is amazing. I would like to suggest an improvment to make it greater.
Get current table / row / column : sometimes script would be great to send an email, generate a bill, … that could be applied to one row only for example. This can be acheived by a function like getCurrentRow().
- Bugfix : When I try to import a base containing script (from a share for example), the script content is overwritten by some HTML.
Thanks
