Joachim
1
How do I connect SeaTable to a webhook?
If I change the status in my table to “Approved”, for example, I would like to start a scenario in make.
In SeaTable I have created the webhook and entered the URL.
But when I change something in SeaTable, nothing arrives!
Am I using the wrong webhook?
In Airtable you can select the individual tables, triggers and more. Here there is only one webhook for everything, if I understand correctly.
cdb
3
Webhook integration with make.com
Webhook Integration with Make.com is just working fine.
- Create a webhook in make.com
- copy the webhook url to clipboard
- create new webhook in SeaTable
- paste the webhook URL to SeaTable
- change some data in your base
why you should not use a webhook
Nethertheless, I would not recommend to use a webhook. It is much easier to use “list rows” module or the search module instead of a webhook.
Webhooks are from my point of view only necessary if you require an immediate reaction in make.com instead of waiting for the scheduler to trigger…
Look here for more details: What are webhooks and what do you use them for? - SeaTable.
system
Closed
4
