Hi guys I’m trying to run seatable in localhost in docker.
but i don´t know what use as SETABLE_SERVER_HOSTNAME in docker-compose.yml
I got this error
I got this error
Generally speaking, a hostname does not include protocol and/or port.
Using SeaTable at 127.0.0.1 does not really make sense. SeaTable would only be accessible from the host.
If you want to run SeaTable in your local network, you should use the local IP address of the host (e.g., 192.168.1.12) instead.
I also took the liberty of changing the title of your thread. Please use descriptive titles so that this discussion can be found by other users.
I have changed the address of the host tho the local IP of my computer, but I got the same error.
I can access to the admin panel
But I got error in each base
Changing the hostname in the Docker file after initialization does not change the hostname in the config files.
Please modify your config files manually or alternatively stop all containers, remove the folders below /opt and restart the installation.
