Strange characters when copying a cell:
In the last days, when I copy a cell with “long text” in the end of each paragraph I get strange characters:
any Idea why?
can you please describe in more detail how you copy the column? By button, into another table and into which column type?
&#x20 is the unicode hex character code for space.
It seems that you have a space at the end of your lines.
The immediate fix is to remove them.
@Leo.Shi Could we fix that code-side?
Thanks for replies.
I’m copying the cell using ctrl+C .
It happens only in the end of paragraph (not every time I use space).
It seems that deleting the space in the end of the sentence does helps.
I will update if the problem repeats.
