Two minor bugs - Linked columns and Long text editor
Hello, here are 2 minor bugs I have found recently:
  1. Changing a column type to a linked column doesn’t display the column in the linked table
Steps to reproduce:
  1. Create a new column, not a link. Text, for example.
  2. On the new column, select Customize Column Type
  3. Select Link to Other Records, select a table to link
  4. The new column works fine, but note that the column for the reverse-link (from the linked table) does not show in the linked table.
  1. As of version 2.6, it now takes 2 clicks on the x in the top right corner to close the long text editor box, where it used to take a single click.
Thanks,
Peter
Hi, thanks for the report.
As for 1: I can confirm the link column is not automatically created in the linked table. Good catch!
As for 2: I cannot reproduce this problem. Which browser are you using?
Hi Karlheinz,
I’m using Chrome Version 97.0.4692.71 (Official Build) (32-bit). I also tried it in Edge Version 97.0.1072.69 (Official build) (64-bit) and I see the same behaviour.
Peter
