I have been collecting a few feature requests over the past weeks.
I’ve had a few more, but glad to see that in the meantime some of them have already been added - good job, thanks!!
Hope that my requests inspire you for future updates
Being able to filter columns of the type “long text”
Color column cells: as a criteria it should be possible to make it based on values in the same row of a different column, now it seems to be only possible to change the color of a cell based on its own cell value.
Color column cells: also for columns formatted as long text - simple options would be helpful: e.g. is empty or not empty.
Cells formatted as long text type: formatting option to cross out text.
Button: Save page design to pdf - additional option to also save the file on the local drive.
Column type Linked records:
when entering the menu with “+” to find/add records, it currently only shows the “add record” when values are entered that do not match any existing records.
If I want to add a record it’d make life easier to have the “add record” option always available in this menu:
When multiple records are linked, usually only a few are shown (depending on the length of the entry and the column width). And if there’s a record cut off, I wouldn’t know if there are even more records linked.
An indicator within the cell (e.g. […]) would help to see if there are more records linked.
Add a link to the forum in the help menu when within a database.
Announcement: We’ll remove the feature request list category from the forum in the future. You’ll be able to post and upvote feature requests on a separate platform.
