EDIT: The unauthorized webhook works. Probably got something to do with the input secret? I was just doing SHA1 checksum of Input secret, did that change to take the body into account as well so I need to calculate the checksum every time?
Hi there, after upgrading my developer edition from 2.7 to 2.8 and then 3.0, my table changes seem to not trigger my webhook properly anymore. I’ve added another fresh webhook to the base without any authentication, but that also doesn’t seem to work. What else could I check or try to see where the issue is? In sysadmin mode I couldn’t find a statistic for webhooks…
Ideally I would be able to just check against the input secret as working before. My tool for receiving the webhook doesn’t seem to get it right now and not sure if I can set it up so that it can generate the hash for input secret and request.body before deciding to validate the webhook call or not.
