Hello, are we able to activate"data processing operation" with api? or using script to process all operation?
Or can we combine two or more of " data processing operation" using a single “button” type in the table ?
I am facing another issue.
I am unable to use automate to trigger “add link”.
i have setup data processing operation as following.
when i trigger the “run” manually, it is working.
when i use the same setup for " automation rule" , it is not working.
automation rule setup
before i change statue to “confirm”
after i change status to “confirm”
I am using 2.7 DE self hosted version.
Yes, please have a look at the scripting manual at Base - SeaTable Programming Manual
Not supported at this point.
SeaTable DE does not support automations. But actually, you should not see the menu item.
maybe this is the reason automation is not working.
anyway back to my 1st question
can i use api instead to trigger the " data process operation" instead?
I am beginner in programming and i think scripting might require a lot of variable to be obtained before i can use the add link. ( for example, I think i have to write code to find out row id for table1 and table 2 which has same value for defined columns in both tables ).
