Add record in linked table with python script
Is there a Python script that would allow to create a new record in a linked table ?
I would like to use this with a button, and it will basically do the same as the Add record that link the current row we are working from to the newly created record in the other table.
This is also interesting for me because then the button will open the newly created record and show calculation information from formulas (in the other table where the record is created) that the Add record cannot show.
I’m sorry, it is rather hard to explain. Basically, a python script to replicate the Add record linking 2 records in 2 different tables. :smiley:
You can write a Python script like below:
# Authenticate using context
base = Base(context.api_token, context.server_url)
base.auth()
# Additional configuration
TABLE1_NAME = 'Table1'
TABLE2_NAME = 'Table2'
LINK_COLUMN_NAME = 'Linked_Records'  # Replace with your actual link column name
CURRENT_ROW_ID = context.current_row["_id"]
def add_linked_record(current_row_id):
    Add a new record to Table2 and link it to the current record in Table1
    :param current_row_id: Row ID of the current record in Table1
    :return: Row ID of the newly created record in Table2
    try:
        # Prepare the new record for Table2
        new_record_data = {
            # Add your custom fields here
            # Example: 'title': 'New Linked Record',
            # Add any other required fields for Table2
        # Add the new record to Table2
        new_row = base.append_row(TABLE2_NAME, new_record_data)
        new_row_id = new_row["_id"]
        # Get the link column ID
        link_id = base.get_column_link_id(TABLE1_NAME, LINK_COLUMN_NAME)
        # Add the link between the two records
        base.add_link(link_id, TABLE1_NAME, TABLE2_NAME, current_row_id, new_row_id)
        print(f"New record added to {TABLE2_NAME} with ID: {new_row_id}")
        print(f"Linked record {new_row_id} to {current_row_id} in {TABLE1_NAME}")
        return new_row_id
    except Exception as e:
        print(f"An error occurred: {e}")
        return None
new_record_id = add_linked_record(CURRENT_ROW_ID)
Does @daniel.pan’s script solve your issue?
Hi, sorry i didn’t get the chance to test it before.
Yes it seems to work as i wished.
One small question is left, do i need to add data in this part ?
Or can i just link empty records?
So far, i tested the code with a new column to add a text such as “Record is linked”
Yes, you can just link empty records.
