Hi everybody !
First of all, congrats for this nice tool
I was wondering why single select columns are not available in formulas (it would be nice to can compare them with a string, for example
if({SingleSelectColum}=“Option1”,1,0)
Thanks a lot, and have a nice day
Hi @bennhatton,
a warm welcome to the SeaTable Forum! We are happy to hear that you are enjoying using SeaTable.
Single Select options are currently not available to be included in a formula. Our applogies for the inconvenience! Hopefully this will be solved in the coming versions, presumably in October or November!
thanks and a nice day to you, too,
best,
Meng
Hi @Karlheinz,
Thank you for you very fast answer !
I can’t wait, Seatable looks so promising so far
Hi @bennhatton, I have some good news regarding your question.
Are you using the self-hosted version or the cloud version?
If you are using self-hosted version which is currently 1.2.0, replace ‘=’ with ‘===’ in your formula, and it should work! It should look like if({SingleSelectColum}===“Option1”,1,0)
If you are using the cloud version, which is 1.3.3 as of today, in which the ‘===’ has been modified to ‘=’, you can just use your old expression and it should work!
Sorry for the confusion and I wish you have a good time working with SeaTable!
Hi, Thank you so much, I’m really grateful for this nice feature ! It will definitely help me, and I think other users too
Thanks for your kind words! Feel free to turn to the Forum any time. Until then, have fun with SeaTable!
