Automation - Periodic with filter condition - No longer working
Hey,
I would like to run an automation, but with a filter condition, in this case name of service provider. However, the Automation is not running with the filter. If I choose to run the automation without a service provider filtered it is working.
This seems to be new with the 4.4 update. Any suggestions?
Best regards
Which column type are you filtering on and with which condition?
It is either single selection or text.
Unfortunately, I cannot reproduce the Issue. The periodic automation with filter on text or single select both worked.
