Autonumber and imported xlsx rows not autonumbering
Hi
i already have first coulmn set to autonumber.
whenever i import new xlsx data, the new rows creates do not have autonumbering applied.
How to fix this?
attached is the image
Hi @pindiplus.
I tried it myself and it worked.
autonumber format is 0000.
it is one of column type.
Are you sure you are using autonumber column type?
Ah, now I understand it.
Do me a favour. Create a new column, switch the type to autonumber and have a look at the description. The number depends how to enter the format for the autonumber.
For example:
  • 0000 means it will start with 0001
I only got it in german language but you will find it in your defined language in the application:
