Dear SeaTable Admins,
The problem:
Do you run your own SeaTable Server and after an update to version 4.2 you only get an “Error” on the homepage of SeaTable?
Then it might be the problem, that you activated departments anytime in the past, and now you have this configuration problem.
Look for the errors:
Open the dtable_web.log
with, for example the command fail -f dtable_web.log
and see if this error occurs if you open the homepage of SeaTable with your browser. If you see this error message, your ran into this problem:
2023-11-23 13:23:06,659 [ERROR] django.request:224 log_response Internal Server Error: /api/v2.1/workspaces/
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/exception.py", line 47, in inner
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/handlers/base.py", line 181, in _get_response
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/views/decorators/csrf.py", line 54, in wrapped_view
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/views/generic/base.py", line 70, in view
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 509, in dispatch
response = self.handle_exception(exc)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 469, in handle_exception
self.raise_uncaught_exception(exc)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 480, in raise_uncaught_exception
raise exc
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/rest_framework/views.py", line 506, in dispatch
response = handler(request, *args, **kwargs)
File "/opt/seatable/seatable-server-latest/dtable-web/seahub/api2/endpoints/dtable.py", line 128, in get
department_v2_groups = get_department_v2_groups_by_user(username).select_related('department')
File "/opt/seatable/seatable-server-latest/dtable-web/seahub/department_v2/utils.py", line 20, in get_department_v2_groups_by_user
for department_id in DepartmentsV2.objects.get_ancestor_departments_ids(department):
File "/opt/seatable/seatable-server-latest/dtable-web/seahub/department_v2/models.py", line 19, in get_ancestor_departments_ids
for dep_id in department.path.strip('/').split('/'):
AttributeError: 'NoneType' object has no attribute 'strip'
The solution
Open your dtable_web_settings.py
and comment or remove these two entries.
DISABLE_ADDRESSBOOK_V1 = True
ENABLE_ADDRESSBOOK_V2 = True
Alternatively, you can set both values to False
Then restart SeaTable with seatable.sh restart
and the problem will be resolved.
