I want to use both Seatable and some kind of *oogle Sheets and sync them from both sides.
- Could you help me to find incoming webhooks (to Seatable) to update and upload data using API.
- In *oogle app script I have a function onEdit() that can send data on any change. What is analog here in seatable?
- I have free account maybe and I didn’t see this option
UPD:
- first link Run script manually, by button or by automation - SeaTable
- it is not clear but option to add ROW is here Add row using fetch https://api.seatable.io/reference/add-row
