Hello everyone, before the new python pipeline architecture, I was able to add python librairies by modifying the python runner image. But now, even if when I enter the container the librairies are successfully installed, I can’t use them in my scripts. There was maybe a solution on the Seatable Admin Manual, but the Github link isn’t working.
Edit: It seems, the custom python runner I made is running constantly, but when I execute a script, another container is used, and I can’t find the conf file who launch another container. And I don’t understand why Seatable would not use one config file to define both containers
Edit 2: Sorry for editing and reversing, each time I test something I think to understand, but no, Seatable is actually using two different python runner, and if I delete the image, it will pull it again, I can’t find which file tells it do so
