It would be nice to have the opportunity to add comments/notes to tables and columns.
Basically I am searching for a possibility to add a description / notes to describe the usage of the column/table.
If there is already a way to do this please let me know, thank you!
Why?
That way you can use Seatable as a test or checklist tool that has descriptions integrated, in combination with the page designer plugin you can create awesome test reports/tools.
