My institute uses a self-hosted SeaTable and provides Common Datasets of some central lists and information that we are using in our tables.
We want to regularly back-up our bases locally, but when we re-import the locally stored files, the common datasets are obviously unlinked and act as a normal table.
Re-adding the common dataset and re-creating all the link-columns is possible, but very tedious as our datasets are comparatively complex and integrated into some scripts which makes this also rather error prone.
My question: Is there a way after import to re-link the table to the common dataset or if not, is there another back-up strategy that retains the link?
Thank you very much in advance!
