I am using the Seatable Node in N8N to get some tables automatically exported to a csv.
Inside the node of N8N (self hosted) it is possible to activate the Option “Convert Link ID”:
But the result is an completely empty column. When the option is deactivated I am getting the IDs.
As far as I see N8N is using the right command (Line 290):
import { INodeProperties } from 'n8n-workflow';
export const rowOperations: INodeProperties[] = [
displayName: 'Operation',
type: 'options',
noDataExpression: true,
options: [
value: 'create',
description: 'Create a row',
action: 'Create a row',
value: 'delete',
description: 'Delete a row',
action: 'Delete a row',
This file has been truncated. show original
Does anybody has an idea how to solve this and get the text instead of the ID?
Thanks!
EDIT: Line
Markus
September 20, 2022, 10:26pm
#2
I’ve also recently had this issue. I have multiple columns with links and needed to solve it by having extra seatable nodes querying the ressources and merging them back together.
It was quite a painful and long process for something that I expected to be done by that option, actually.
Just a quick taste:
The subworkflows query each resource in turn, and in the end I assemble the data.
let objekt = $items("get Objekt")[0].json;
objekt["Wohnungseinheiten"] = $items("Assemble Wohnungseinheiten").map(item => item.json);
objekt["Garage / Stellplätze"] = $items("Assemble Garage / Stellplätze").map(item => item.json);
objekt["Grundrisse"] = $items("Assemble Grundrisse").map(item => item.json);
return objekt;
Maybe you can use a similar approach until this is fixed!
Tom
September 21, 2022, 5:21am
#3
Right now I don’t have a system to reproduce this at hand, but it sounds to me now with two confirmations that it should be reported upstream in the N8N issue tracker:
or alternatively in the community forums:
IIRC from SeaTable API use, the link / table relation can flip depending in which table the link was created. Perhaps it’s just an off-by-one error looking up the ID in the wrong table and then getting empty results, but as written, I can not reproduce this right now, sorry.
Thank you.
@Markus : Great workaround, but I think it will get messy to fast for me…
@Tom : Thanks. Then I am assuming that the Code I mentioned is basically correct and the problem must be somewhere else. I´ve made an Issue for that in Github: Seatable Node: Convert Link ID not working · Issue #4155 · n8n-io/n8n · GitHub
FYI: The solution for this is currently waiting in a push request.
Markus
October 15, 2022, 2:04pm
#6
Can you update here when it’s through? I might have to adjust my workaround
Yes! It works. I found time now to apply the N8N Update and test ist. Works very well.
system
Closed
October 22, 2022, 10:22am
#8
