Hi there.
I am developing a new table in a base. During the development process I don’t want this table to be visible to the other users in the base.
As far as I know I can’t make a table hidden for the other users. Is that correct?
Ofcourse I can create a new base and start developing the table there, but when finished developing the new table it should be placed in the other base. Is there an option to copy a table to another base?
I looked at exporting/importing, that doesn’t do the trick. I can only export in Excel format and import in CSV format. This means converting the file. And more important, I lose all column properties/settings/formulas.
Can you help?
Thanks !
Peter
