CSRF iframe verification failed
Hi - inserted a seatable link into an ifram, but it stopped working, I get the following error:
"Verboten (403)
CSRF-Verifizierung fehlgeschlagen. Anfrage abgebrochen.
Sie sehen Diese Nachricht, da diese Seite einen CSRF-Cookie beim Verarbeiten von Formulardaten benötigt. Dieses Cookie ist aus Sicherheitsgründen notwendig, um sicherzustellen, dass Ihr Webbrowser nicht von Dritten missbraucht wird.
Falls Sie Cookies in Ihren Webbrowser deaktiviert haben, müssen Sie sie mindestens für diese Seite oder für „Same-Origin“-Verbindungen reaktivieren."
I tried Firefox and Chrome with no luck.
This is the Link I used: https://cloud.seatable.io/dtable/view-external-links/custom/***/
Any ideas how to solve this issue?
Greetings Nico
Please note this:
https://forum2.seatable.io/t/csrf-verification-failed-when-logging-into-invitation-link-in-embedded-iframe/1097/3?u=rdb
If you need an example for integrating external ilnks in a webpage, have a look at our press page: SeaTable press area
I noticed the thread and I did some research. The iframe link is working, but only if you dont add a password.
I tested it right now:
link without password = working
link with password = error
So I need a password, any chance for getting it work?
Greetings Nico
Hey Nico,
I am sorry but we will not allow password protected views via iframe. We cannot weaken the CSRF checks because this will lower the security of cloud.seatable.io in general.
If you want to keep the password protection, then create an preview-image and link it to the correct url. Or if you don’t want to send the user to cloud.seatable.io then you have to protect your view with another kind of protection like HTTP-Basis Authentification in your webserver or add some code like php or python pending of your website language.
Here is a short link how to use http basic authentication in nginx: Restricting Access with HTTP Basic Authentication | NGINX Documentation.
If you have apache use this manual:
Authentication and Authorization - Apache HTTP Server Version 2.4
Best regards
