Hi! I’ve been wanting to give SeaTable a try but unfortunately I can’t get it to work.
I want to use SeaTable without the automatic LetsEncrypt certificate feature because I will be proxying it through my frontend Nginx instance which already has a certificate. After following the steps in the documentation (Redirecting...) and setting up my reverse proxy configuration (see below), I get a Django CSRF validation error.
- I’ve tried to replace
http://
withhttps://
indtable_web_settings.py
andccnet.conf
(and restarting Seatable service or container, both ways) but it did not help. - I’ve tried adding
mydomain
under a newCSRF_TRUSTED_ORIGINS
option, but it did not succeed either. The DjangoDEBUG
option also didn’t give me any substantial hints (just saying thatmydomain
isn’t a trusted origin). - I’ve also tried to use it with
SEATABLE_SERVER_LETSENCRYPT=True
(after removing all containers and bind mounted directories), but I hit the same issue as in https://forum2.seatable.io/t/seatable-1-8-developer-edition-docker-fresh-installation-broken/461 (where you get[...] open() "/etc/nginx/sites-enabled/default" failed [...]
in the seatable logs) and I could not get it to work as per the answers (that is, making sure that it is set toTrue
when the containers are initially created).
Thanks for any help,
Niklas
My docker-compose.yml
version: '2.0'
services:
memcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
restart: unless-stopped
db:
image: mariadb:10.5
environment:
- MYSQL_ROOT_PASSWORD=REDACTED
- MYSQL_LOG_CONSOLE=false
volumes:
- ./seatable-db:/var/lib/mysql
redis:
image: redis:5.0.7
seatable:
image: seatable/seatable:2.1.0
ports:
- "127.0.0.1:12001:80"
volumes:
- ./seatable-data:/shared
environment:
- DB_HOST=db
- DB_ROOT_PASSWD=REDACTED
- SEATABLE_SERVER_LETSENCRYPT=False
- SEATABLE_SERVER_HOSTNAME=mydomain
- TIME_ZONE=Europe/Berlin
links:
- db
- memcached
- redis
My reverse proxy configuration:
server {
server_name mydomain;
listen 80;
listen 443 ssl http2;
include i.d/acme.conf;
if ($scheme = http) {
return 302 https://$server_name$request_uri;
client_max_body_size 512M;
location / {
proxy_pass http://localhost:12001;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Host $server_name;
proxy_set_header X-Forwarded-Proto $scheme;
