Data processing automation
[SOLVED: The option to trigger a data processing operation can be chosen when using the periodic trigger option.]
I use seatable cloud enterprise.
I use a data processing action that needs to be manually triggered. I read once that SeaTable will be making it possible to automate data processing actions.
My situation:
Bildschirmfoto 2023-10-18 um 14.33.08
Works fine as data processing. But can this be automated with an automation rule?
Definitely this is possible: Perform data processing operation by automation - SeaTable
Important: The automated action "Execute data processing operation " is only available at the trigger event “Periodic Trigger”!
